iPhone 12 consistently restarting after 3 minutes.
Hi,
I'm a tech repair hobbyist and I've purchased this iPhone 12 that has restart problems. After verifying the issue, I reviewed the panic logs and found that it could not communicate with 'Thermalmonitord' and the sensor in question was 'prs0'. Although I could not find any details on the location of this sensor for this model of phone, I found that people were having success on the iphone 11 series by replacing the charging port. After replacing the charging port with an OEM replacement the issue is still present, as such I'm turning to the community for help.
Does anyone have any suggestions on where this pressure sensor is and which part I would need to replace?
If you would like to see the full panic log I can also provide it.
Cheers,
Tom
2 Comments
So you replaced the charge port with one pulled from another working iPhone 12?
by Chris Stables
@imicrosoldering Unsure if it was pulled however, it was labelled OEM by a reputable brand. https://repairoutlet.co.uk/products/for-... Do you think this port is also missing the sensor?
by Thomas Watson
