Model A1288 / 8, 16, or 32 GB capacity
583 Questions View all
How can I remove wifi ribbon adhesive from logic board?
I removed the wifi ribbon cable from my 2nd gen ipod touch and it left some adhesive behind, how can i clean the logic board of the adhesive?
Add a comment
1 Answer
Chosen Solution
You can use some isopropyl alcohol. Use the highest percentage available to you. I would not use the rubbing alcohol, it does have plenty of other stuff in it. Talk to your local pharmacist and see if you can get a 90%. Use a soft toothbrush and carefully scrub the area. Make sure you do not knock of any of the components ;-)
Score 2
Comments:
Thanks,
I will give that a try.
by
Add a comment
Add your answer
Tom will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 372
