M65-D0 - Bad Backlight, is it the power supply or LED strips?
I have a M65-D0 TV that appears to have a bad backlight. The video works fine and you can see it when you shine a flashlight on the TV, but the backlight is out. Presumably it's either the power supply, backlight inverter, or the LED strips.
I've tested the following pins on the PSU that lead to what I think is the backlight driver/inverter, shown in the photos below. Vdrv 1-7 all read 25V. Is that the normal voltage that should be going to the backlight driver/inverter (the center component in the big picture).
Should I be testing elsewhere?
