Repair guides and disassembly information for the 16-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2485.
68 Questions View all
MBP 16" 2021 Weird mainboard element which I found broken...
Hey! Can you tell what are these small black little things on MacBook Pro 16" 2021 mainboard? I wonder because I found one torn apart. I straightened it, however it is no longer fully soldered. Though it's broken my MBP still works.
Add a comment
1 Answer
Chosen Solution
It’s a isolation stud used to support the logic board from twisting about. similar to the one just above which is a spring version for EMI. This one is insulated.
You should be able to just glue it down so it is able to continue to work properly.
Score 1
4 Comments:
So I don't have to be worried that something will stop working?
What kind of glue should I use?
Thanks for answers! :)
by
@szarik00 - You just don't want it floating around.
Some logic board epoxy should do.=
by
@danj You mean floating when using keyboard? Just trying to understand, because mainboard is screwed to the case.
by
@szarik00 - Allowed to break free
by
Add a comment
Add your answer
Adrian Jelonek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 76
