Model A1213 / 8, 16, or 32 GB capacity
277 Questions View all
I can see the icons, the touch works, the screen is black?
iPod Touch 1st Generation works however the screen is black, i can see the icons and the touch works
Comments:
Thanks for your help, I’m confident that your answer is the problem.
Thanks Again,
Ron
by
You are welcome and best of luck to you.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Ron, if the icon etc. are visible, that means your backlight is not functioning. The backlight is part of the LCD, and the backlight circuit is on the logic board. I would go ahead and start with the cheaper of the solution, and that is by replacing the LCD. Of course, make sure that you restored the iPod and have done any of the updates and also reset the settings. From the Home screen->Settings->General->Reset All Settings. If none of that works, you are looking at having to either replace the logic board, or replace the coil on it. The replacement of the coil is very tedious, very small and needs some special skills. iPod touch has no backlight for a picture of the coil.
Hope this helps, good luck
Score 2
Add a comment
Add your answer
Ron will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 424
