Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
CD/DVD rom disk drive rejects disks
Out of nowhere, my MacBook just stopped accepting disks, both cds and dvds. I'll put a disk into the drive, and it will make noises like it's attempting to read it. It does this in a cycle of three, like it's trying three different times to read the disk. And then, after the third attempt, it just spits the disk back out, rejects it. The disk doesn't get stuck in the drive, on the contrary, it never stays in. Is there any way that I can fix this myself, or is my disk drive just fried? I don't think I did anything to it to make it stop working, it just stopped one day.
Score -1
1 Comment
If you need a replacement drive we will need your exact model. Take the battery out and look on the identification plate on the inside. There should be a A1XXX number, the GHz number, if it's 13", 15", or 17" machine and a EMC#. Thanks so much
by
Add a comment
Chosen Solution
You might try a lens cleaner disk. It may clear your problem. If not you may have a bad drive. You can probably get the cleaner disk at Wal Mart or Radio Shack. Good luck. Ralph
Score 4
Add a comment
A Lens cleaner would be my first recommendation like RJ wrote, and if a clean install of OS doesn't help, I would try reseting the PRAM and PMU. And, if all else fails, you might need a new drive:
http://www.ifixit.com/Parts-Store
Don't know the exact model you have but you can search here for the optical drive you need.
Score 1
Add a comment
From my experiences, the optical drive on the plastic MacBooks (I don't know about the late 2009 version) has a tendency to go bad. This is due to its placement at the edge- if you pick the laptop up with one hand on the right side, you can damage the drive somehow. I've dealt with 4 MacBooks of your type, each with a bad optical drive. Usually, it's because it's been damaged through being picked up there.
Score 1
1 Comment:
I have an early 2009 MacBook, it's good to know these things. 2 hands from now on! :0)
by
Add a comment
How does one get the cleaner disk to not be rejected?
Score 1
1 Comment:
heh, i dont think, you can get it to stay...
i once got a cleaning disk with one of the Mozarts symphonies... as it was audio disk, it got played in my cd player. however, any computer drive have rejected disk. even so, it still does the job.
also, it depends on if it is a "dry" cleaning disk, or "wet" disk...
by
Add a comment
i have problem my mac book laptop , sound card and cd rom not working but i show sound card logo(icon ) on top of bar kindly please tell know what problem incur my laptop ?
1 Comment:
Different issue - open a new question, please.
by
Add a comment
Hallo everyone, i have a black macbook (late 2007) as in this post, it reject all the dvds and cds, but he didn't reject the cd -dvd cleaner, after the cleaning i tried again to put a dvd in but it rejected the dvd ..
marco
Add a comment
Try this. Do not know if it will do it.
https://discussions.apple.com/thread/315...
Add a comment
Add your answer
Brie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 8,171
