Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Questions View all
RAM Type and Configuration?
Hello!
My Question has 3 parts.
a) MUST the iMac Mid-2007 20" EMC 2133 use PC2-5300 or will it run the PC2-6400?
b) I believe it will run up to 6GB of RAM, although not officially supported by Apple?
c) Must both slots carry equal amounts of RAM, eg. 2x2GB, 2x3GB, or can I configure unevenly, eg. 1x4GB + 1x2GB, 1x2GB + 1x1GB, etc.
Thanks!
Taylor
Add a comment
1 Answer
Chosen Solution
Standard RAM: 1 GB
Maximum RAM: 6 GB*
Details: 1 GB of RAM is installed as a single module.
*Apple officially supports 4 GB of RAM, but third-parties have been able to upgrade the system to 6 GB of RAM using one 2 GB and one 4 GB memory module.
  • Supported RAM Types
The "original/Mid-2007" Aluminum models -- the iMac "Core 2 Duo" 2.0 20-Inch (Al), "Core 2 Duo" 2.4 20-Inch (Al), "Core 2 Duo" 2.4 24-Inch (Al), and "Core 2 Extreme" 2.8 24-Inch (Al) -- use 667 MHz PC2-5300 DDR2 SO-DIMMs, which Apple further specifies must meet all of the following criteria:
PC2-5300
Unbuffered
Nonparity
200-pin
667 MHz DDR2 SDRAM
The "Early 2008" Aluminum models -- the iMac "Core 2 Duo" 2.4 20-Inch (08), 2.66 20-Inch (08), 2.8 24-Inch (08), and 3.06 24-Inch (08) -- use 800 MHz PC2-6400 DDR2 SO-DIMMs, or specifically:
PC2-6400
Unbuffered
Nonparity
200-pin
800 MHz DDR2 SDRAM
Score 4
2 Comments:
@ Mayer: Thanks for your infos,
but imho this is correct, but not the answer to the first question.
The 1st question is: will the iMac7,1 –NOT the iMac8,1– also accept 800MHz DIMMs. like some other 667MHz Mac models do ?
The answers to questions 2, and 3 are correct.
by
@klausfinke The EMC2133 only has two models, both 7,1. Your information is incorrect
https://everymac.com/ultimate-mac-lookup...
by
Add a comment
Add your answer
Taylor McAuslan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,447
