How to Change out charging port
My son damaged his charger and then jammed it into the charging port damaging it. Now I need to replace it and feel comfortable doing so based instructions online for similar devices but I want to make sure to order the correct replacement part. Can anyone help? The device is a Lenovo Chromebook C340-11
Add a comment
1 Answer
Most Helpful Answer
Hi
Here’s the hardware maintenance manual for the laptop.
Go to p.31 to view the necessary pre-requisite steps and then the procedure to remove/replace the I/O board (supplier example only).
Search online for 5C50S24976 to get results for suppliers that suit you best.
Score 3
1 Comment:
This was so helpful, thank you so much!! I was able to remove the I/O board and I got a replacement ordered and on the way!
by
Add a comment
Add your answer
Brooke Gullett will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 345
