Released in November 2020, the 13" MacBook Pro features Apple's Arm-based M1 SoC with both an 8-core CPU and 8-core GPU. (Model A2338 / EMC 3578 with two Thunderbolt 3 ports)
76 Questions View all
The laptop does not charge, can anyone assist?
Hi
I have just had this MacBook Pro 13" Two Thunderbolt Port Late 2020 to repair its screen but noticed before and after screen replacement it does seem to charge as I’m not using the original USB-C charger? Would this be the problem?
Add a comment
1 Answer
Most Helpful Answer
You do need to use the correct wattage charger either the original 61W USB-C Power Adapter or the newer 67W USB-C Power Adapter Using anything less will likely not work.
The given USB-C cable needs to be a power version vs a data version. Not all cables are wired fully and/or don't offer the correct gaged wires so it can't properly power the system USB-C Charge Cable (1 m)
Score 1
2 Comments:
Thanks Dan this worked
by
@Tracey Homeward - Happy it worked out! Don't forget to accept the answer - Thanks!
by
Add a comment
Add your answer
Tracey Homeward will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 68
