55eg9100 red light flashes 3 times then nothing
My lg 55eg9100 wont turn on it clicks one time then the light flashes red 3 times and turns off. I have tried the turn off wait and turn on and hold the power button method i read about but nothing changed. Plugged into different outlets too, nothing. Please help
Update (01/28/2022)
would you suggest replacing the resistor that goes to the 12v on? Because the only board i found that was reasonably priced sub $200usd was ver 1.4 and mine is a 1.1 there were some differences between the two.
3 Comments
No. 18 12v on has no power everything else is ok
by Ryan young
That is your power on so looks like you are having issues with the power board.
by oldturkey03
Do you have power before and after R2322? If so then you should not have to. If you do not, then you will have to check around Q2301
by oldturkey03
