Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Where do I get replacement Phillips screws?
Lost the 1.6mm Phillips screw that is one of two screws that hold down the "thin steel dock connector cable cover". Where can I get a replacement screw? Or other screws if I need them for that manner.
Score -1
Add a comment
1 Answer
Chosen Solution
you can get them from here and even here are some. Hope this helps, good luck.
Score 3
3 Comments:
Good answer +
by
Thanks for the answer; much appreciated. Found them on Ebay too. Cheap. $2.97 for the WHOLE set! And... would you believe I found the missing screw on the floor!?
by
Happens to me all the time :-) Good Luck
by
Add a comment
Add your answer
alberts9 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 248
