The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
186 Questions View all
How do I fix striped screws?
I recently bought a 2ds to play on but it came in with a broken screen. I didn’t feel like returning it because the repairs look easy. When I was unscrewing the back screws I added too much pressure so in result two of the screws became striped of its grip. I tried a few methods like using a rubber band, using a bigger screwdriver, and using super glue to a stick a popsicle stick to the screw. None of the methods worked and now am stuck and don’t know what to do.
Add a comment
1 Answer
Most Helpful Answer
If you don't want the screwdriver or the stripped screw back, (unless you can remove super glue) superglue the screwdriver to the screw.
Score 1
Add a comment
Add your answer
Romeo2004x will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 92
