Shuts down during Charging
When using different sources, ie computer or wall adapter with standard usb chord from samsung the phone will shut off in a matter of seconds or not recognize and not charge,
Thanks
Thanks
check the pins on your battery
if the middle pin (data) is not touching the phone IT WILL SHUT OFF
I had the same problem
you need to charge it with another phone
then it will work..never let your battery go flat..
these type of phones always have problems with charging
i had to buy a table top charger to charge the battery then put it in my phone... or better still buy a tabletop charger and as pare battery.
my galaxy s 4g had the same problems. are you trying to charge it while its on and below 5% battery?the cell phone store told me that when the phone is being charged when its really low and using a lot of apps at the same time it goes into overload..my suggestion is to keep it above 15% and try to find a battery saving app that can help you turn off some things that might be running in the background all the time.but some usb cables are made for data only and not charging they provide a charge but sometimes its not enough to keep the phone from dying.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 7,290
