The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
282 Questions View all
2g touchscreen not responding
Are the 2G iPhone and the iPhone 1st Generation the same? This link calls it 1st Gen ( ). In any case, I believe I have a 2g, and the touch screen does not respond to touch. I understand that the digitizer and screen are 2 in 1 and that I need the complete part(s) but do not see it on your site, nor the blue prying tools. Can you and me the link to the tools? I saw them yesterday for $2.95 or so.
Add a comment
1 Answer
Chosen Solution
not worth fixing..cost too much for the parts.
as the front and lcd and glass are all one unit.
will cost you around £170 and are getting rare now.
Thanks. The problem this 2g is that the touchscreen did not respond to touch ( now wont turn on at all). I read omewhere within this site that the connector might be loose. I tookit all apart, and as soon as one of the cable loosen up, the screen went off. Mind that I could not turn it off due to the screen not responding, or sliding off. It was a fustrating to take apart, so I'll try once more and see if in fact reconnecting everything will fix it, otherwise, it may be just worth recycling. Thanks again.
Add a comment
Add your answer
Robin Loor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 2,122
