My HP Pavilion dc6000 is overheating?
The hardedisc is burning hot and my CPU fan is going bananas, disenoing noise that very alot.
My PC is slowing down and some times is going to stand still..... what can I do to fix this and what hardeware do hawe to change.
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Chosen Solution
Here is a link to the service manual for your unit. I would use it to open up your computer and clean the fans and interior of debris. You may also want to redo the thermal paste under the CPU. Hope this helps.
http://h20000.www2.hp.com/bizsupport/Tec...
http://bizsupport2.austin.hp.com/bc/docs...
Score 5
Add a comment
I've worked on the HP Pavillions and I can tell you that redoing the thermal paste should definitely fix the heating issue, if it hasn't overheated to the point that it's damaged anything already, that is.
But it's only 10 bucks, a coffee filter, latex gloves and rubbing alcohol, so not too much of an investment to at least try it.
Add a comment
Add your answer
John Jahreie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,483
