The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Switch screen show a very dim gray screen.
I was working on my switch. I’m not sure if I damaged the LCD or not. When I turn the switch it take a couple minutes the fan spin and nothing pops up beside a light gray dim. I’m not sure if I need to buy a new LCD or not
1 Comment
Hi! Where did you worked on? Did you replaced something? Could be the LCD, but could also be some component on the motherboard has died.
by
Add a comment
1 Answer
Chosen Solution
Sounds like and lcd connection issue as the gray screen your referring to is backlight. You have maybe damaged the lcd connector when putting the ribbon back in or it’s not in correctly.
Score 1
1 Comment:
Yes that is what I was going to say. Sounds like it could be the problem.
by
Add a comment
Add your answer
Coupyz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 39
All Time: 2,041
