Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3233 Questions View all
Is it possible to replace only front glass?
hi, my iPhone's front glass broke and i paid a lot of money for replacing whole of lcd!!!! could i change the front glass only???
I'm really really upset because of what I've done??
it trashed my beautiful iPhone.
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Chosen Solution
Unfortunately, the front glass and the LCD are fused together, so you cannot separate them. You have to replace the entire display assembly.
Score 1
Comments:
big debates about this..for quality of finish and ease you should buy the entire LCD/digitiser glass. You CAN'T take the glass off the LCD..we've all tried and failed. You can buy the 2 parts and assemble as one so that in the future if one or the other breaks you could just replace 1.
by
Add a comment
No... tried on a iPhone 4 with a bad logicboard that fell in the ocean I was given
I did not come close at all(corner of the screen cracked)
BTW, the connector was corroded beyond repair for the digitizer used
Score 1
Add a comment
Add your answer
akbar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 408
