Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
upgrade fusion drive from 128gb to 1tb and remove hdd
hi;
A year ago I had split my HDD & SSD Fusion Drive and upgraded SATA HDD to SSD was going on with just SATA SSD and leaving the blade SSD unused.
Now I want to upgrade my blade SSD capacity & just use it as a hard drive?? is it possible?
Or, maybe one more step; using fusion drive as just one drive and other hdd (ssd) as time machine ???
Are these possible ?
Add a comment
1 Answer
A Fusion Drive is confusing!
Its made of two physical drives a SATA HDD (spinning rust) and a PCIe/NVMe blade SSD.
So what you did in breaking the fusion drive set and then replacing the HDD with a SSD got you some performance but you still have the PCIe/NVMe interface which presently has a wimpy drive size-wise as its function was a cache drive to speed up your HDD’s access not large enough to do much anything else.
So you could replace the blade drive with something larger iMac Intel 21.5" EMC 2638 Blade SSD Replacement going with 48GB or larger! Then make it your boot drive and holding your apps. Then leaving the rest of the space unused for systems virtual RAM, caching and depending your apps scratch space. Here in this config we are using the SATA drive SSD as your data drive to hold your work and other media content.
TimeMachine requires an external drive to be your safety line when your system goes down. Having it internal would prevent you from getting your system serviced and still be able to access your stuff.
As an example I have a few external drives strictly for backups as a photographer I hold my projects on external drives and only hold my current work on the system with my iTunes music.
As we don’t know your workflow is we can’t give you much more.
Add a comment
Add your answer
Atilla Erkut will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 141
