CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
419 Questions View all
Where do these 3 clips go? Verizon iPhone 4 rebuild. Help!
There are three clips, maybe grounding or antenna clips and i can't remember where the go, i am pretty sure the solid brass/gold one goes on the top of the logic board, and one goes on the battery screw, but there is a third as well.
Are there any pictures that show where these go? Originally i had tried to just replace the glass, but in the process the LCD assembly fell apart, so i order the glass/LCD combo replacement.
Thanks for any advice and help.
Mac
Score 1
Add a comment
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Chosen Solution
You can see two of them at step 17 and step 22 of the logic board guide here :
iPhone 4 Verizon Logic Board Replacement
Score 3
Add a comment
The 3rd and 5th pictures are of the same part (camera ground). The part in the 2nd picture is in step 10 of the same document (logic board pressure contact)
Installing iPhone 4 Verizon Logic Board
Add a comment
Add your answer
Mac MacAnanny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 4,531
