Why are there black blobs and lines going across my 58 in hisense tv
My 58 in hisense tv has black blobs on the right edge of the screen, 4 lines going across the screen and recently started flashing white light
@jp082119 darn that is a broken LCD screen. There is no fix for it. The only thing you can do is replace the panel. Panels that size, if they are even available, cost more than a new TV, What I suggest is that you try to purchase a TV that is broken other than the screen and harvest the screen from that. OR you can try and remove the back cover from your TV and use the panel model number that is on a sticker on the back of that panel and try to find a good used one. The only other thing to do is to remove the boards from your TV and sell those separately. Then take the rest of the TV for recycling and invest in a new TV. Nothing here is good news but that is really the only thing you can do.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 32
All Time: 732
Can you take a picture of the problem and post it as an update to your question? Adding images to an existing question
by Andrew S
@jp082119 the "blob" issue does not sound good. "Blobs" are usually bad LCD's in the panel but like @andrewsawesome post some pictures of what your screen shows.
by oldturkey03
Thank you, my tv is only a year an half old and I didn't get a extended warranty with it...dumb I know, but I still think to myself if it's cheaper to fix the tv than buy a new one.
by Pjay
Wow, thank you very much. We are pretty mechanically inclined so that's a really good idea, I will check into a broken TV if I dont succeed with that maybe a new panel, or maybe it's just time to save for a new TV unfortunately
I'm not sure how it would have gotten broken...but somehow it did. Greatly appreciate your help with this .
by Pjay
looks like it started on the righ hand side right by the bezel. that is where I usually grab the TV's I have to move. So who knows maybe just a bit to strong a grip may have caused the fractures. Sorry, wish I had better news. Always bites when that happens.
by oldturkey03
