The HP Compaq 6730b is the "business" edition of the 6730 laptop line released by HP.
5 Questions View all
Stuck on starting windows screen
Hi my laptop is stuck on starting windows screen really slow to start up
1 Comment:
How slow is it? Is the OS installed on a hard drive or solid state drive?
by
Add a comment
1 Answer
Factory Reset:
You could try to do a factory reset on the computer (you can find it in settings and lookup factory reset) but before you do make sure that you backup all of your important files/files you would want to keep(Photos, Documents, etc.) because it will delete All of your files
Upgrading to an SSD:
If your computer has a hard drive, you could try to upgrade it to an SSD which will make loading times much faster but also make sure to backup and/or transfer your files to the SSD
Add a comment
Add your answer
John James will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 179
