The 7th-generation Surface Pro, released in October 2019. Available in platinum and black. Model number: 1866.
Is Microsoft Surface Pro 7 i7-1065G7 overheating fixable?
Is it worth to try change a cooler or repaste? Given that I almost certainly will break the screen?
Add a comment
1 Answer
Most Helpful Answer
does the cooling device turn on and attempt to run? if so first try a repaste, if not you would then have to change the cooling device.
Score 1
1 Comment:
Yes, it does. Thanks!
by
Add a comment
Add your answer
Wi Vi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 286
