laptop display goes black when unplugged
ASUS laptop R554L has no display while unplugged
As others have mentioned, I would confirm that the computer is still on and operating normally while unplugged by hooking it up to an external monitor and confirming the image is showing there normally, even if the screen is dark on the monitor itself.
Per resources, it seems a common issue is that your screen brightness overall or the brightness of the unplugged mode is likely too dark.
This post from another forum (https://superuser.com/questions/666410/l...) mentions a very similar issue with another Asus laptop and the resolution was to edit the Power Options within Control Panel (Windows Button > Control Panel > Power Options > Change Plan Settings for desired plan > Change Advanced Power Settings > Display > Display Brightness and ensure you are editing the option for unplugged.
If that doesn’t work, there MAY be a driver issue with the display, Asus support for the R554LA appears to be here: (https://www.asus.com/us/supportonly/R554...) but while relatively simple, replacing monitor drivers on your primary computer without a backup or experience may lead to issues with your display, not allowing you to be able to see anything you are doing on it.
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 87
All Time: 3,961
Power management settings or faulty battery...all I know
by [deleted]
What I'm saying is my laptop still runs when unplugged it's just the screen goes dark or blank when unplugged. When I plug it back in it's at the same place on the screen before being unplugged! I have played with the power management with no success!
by Neil Morris
Battery is fully charged as well
by Neil Morris
@Neil Morris
Very curious this is! It has a cause so there will be a solution - as in all things.
What about with an external monitor/TV ? Same?
<F4> button to switch between internal and external monitor
Battery Calibration:
https://rog.asus.com/forum/showthread.ph...
and
https://www.asus.com/support/FAQ/1032726...
Have you checked the battery contacts? Anything look bent or the like?
Have you run the MyASUS System Diagnosis tool ?
by mike
@Neil Morris
I have been thinking that probably the battery just needs recalibration - that's all!
Run the battery calibration as mentioned above.
by mike
Show 3 more comments
