Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
949 Questions View all
iPhone X slightly bent, Solder two layers together
How do I solder two layers back together when the top layer is slightly bent at the top?
Thanks in advance!
Comments:
@iammyron07 two layers of what? Has the screen separated or the logic board? Give us more detail
by
Add a comment
1 Answer
Most Helpful Answer
If it is the front of the board that isn’t connecting I wouldn’t be too worried as they are all ground pads. If it is bent significantly you will need to solder the spacers back on and clamp it down while heating.
 I think there are about 8 spacers. You might have to get them from an unseparated IC board if you haven’t saved any from the other boards.
Score 1
Add a comment
Add your answer
Myron. will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 12
