Repair and service information related to the ResMed AirSense 10 CPAP machine. Also known as the ResMed Air10.
22 Questions View all
Very high leak rate on report screen
I get very high leak rates 40 to 70 L/min indicated with no mask seal alert and no warnings. Mask,tank,and tube all check good with no leaks
Add a comment
i have same problem i fix it by replacing the mask and program the cpap with the new mask .. it works.
Add a comment
I have the same issue. I’m replacing the first internal gasket before I try the harder to replace air pump gasket. https://www.directhomemedical.com/resmed...
Add a comment
Add your answer
William Kracke will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 28
All Time: 321
