The Samsung Galaxy S9 is identified by its model number: SM-G960XU. It is the ninth generation of Samsung's Galaxy Series that was released in March 2018. Available in Lilac Purple, Midnight Black, and Coral Blue.
124 Questions View all
Samsung Galaxy S9 motherboard swap
I have purchased a fully working Samsung Galaxy S9 and will be swapping the motherboard from the old phone to new phone. ( will be cleaning the original motherboard from water damaged phone using some 99.9 isopropyl alcohol prior to swap and hope for the best, I believe the motherboard is OK and just the screen on the original phone was damaged.)
What I need to know now is on the new phone prior to swap, do i need to go through setting up the new phone prior to motherboard swap or do I swap before doing phone setup or does it not make any difference either way?
Thanks
2 Comments:
Thanks everyone. the motherboard swap worked.
So a Galaxy S9 motherboard survived a full wash cycle in a washing machine just damage to touch screen only.
Purchased a mint condition S9 off ebay for £134 and having cleaned the original motherboard from water damaged S9 with 99.9% Isopropyl alcohol and swapped it over to new replacement phone and powered up the phone everything works!!!
Thanks for all the advice.
by
Good job! Happy it worked
by
Add a comment
1 Answer
Hi,
If I understand.your question correctly, just go ahead with the swap. It makes no difference.
There are no setting to adjust when swapping motherboards.
I hope this helps
Add a comment
Add your answer
diezeltruck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 161
