Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
broke ribbon replacing screen, what does it do?
well i replaced my screen on my iphone 4 but when i was re-assembling i broke one of the ribbons, out of the 5 main ones it was the middle one, so i went ahead and still plugged it in even tho the other side wasnt attached to any thing, turned the phone on and everything seems to be working, camera, text, phone, speakers, flash, internet, home button, touch screen and anything else i can think of. my question is what does that ribbon do? and should i expect bad things now?
Add a comment
Chosen Solution
The middle one you mention is the headphone / volume / mute button cable.
You probably are not able to use the headphone output as well as the mute and volume buttons anymore, that's all.
Can you check if these functions still work or not?
Score 3
Comments:
Yupp that would be it, how hard is it to replace this?
by
Not too hard if you know what to do. Have a look at the guide to see how to do.
by
Add a comment
I broke the first one (starting from the left) and i did that same thing- plugged it in even though its broken. My iphone wont turn on though, is that the problem?? it vibrates, but nothing on the screen will show up.
Add a comment
Add your answer
william jones will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,404
