Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1623 Questions View all
MacBook Pro's screen turns grainy, flickers and turns black
I recently received this macbook from a relative which seemed to work without a problem but recently, when turning on the laptop the screen would look grainy then after a while it would flicker and finally some parts of the screen would just be black. I tried the Apple Diagnostics (pressing D at the start) but it didn’t mention any issue. I also tried formatting my HDD from Internet Recovery and still nothing, also to mention that during the diagnostics and recovery the screen issue didn’t happen. I finally tried booting up in safe mode and it seemed to work but when i booted it normally the problem persisted.
Here is a video of the problem: https://youtu.be/bBTXtjmlfbs
I really don’t understand what the problem is, I would really appreciate some help. Thanks!
Score 1
4 Comments
Does an external display look OK connected to the Thunderbolt port (mDP or TB display or via a HDMI/VGA adapter)
by
what Dan said.if external display work, then it's the panel. if so, open the case try reseating the lcd, check the pin for corrosion or bent pins.
if the external display doesn't work then it's the motherboard or gpu issue.
by
I just tried it with an external display, it shows the same issues as the laptop's screen.
In this case does it mean that it's a motherboard issue? Is there a way to fix it?
by
I maybe the RAM
by
Add a comment
1 Answer
Chosen Solution
Ouch! Sadly thats the sounds like the CPU thats failed you! This series uses the intergraded graphics engine within the Intel chips HD Graphics 4000.
You could try replacing the RAM as this series leverages it for the video RAM. But given the symptoms I don’t think that will help (204-pin PC3-12800 (1600 MHz) DDR3 SO-DIMM) support for upto 16GB MacBook Pro 13" Unibody Mid 2012 RAM Replacement
You’ll need a new logic board MacBook Pro 13" Unibody Mid 2012 Logic Board Replacement
MacBook Pro 13" Unibody Mid 2012 Logic Board Image
Guide
Difficulty:
Difficult
45 minutes - 1 hour
MacBook Pro 13" Unibody Mid 2012 RAM Image
Guide
Difficulty:
Easy
15 - 30 minutes
Add a comment
Add your answer
Marcelo Marquez will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 69
