The G502 was released in 2013, and its already ergonomic design was transferred to the G502 Hero in 2018. It features a 16,000 DPi sensor and a scroll wheel with a smooth, gliding scrolling feature.
10 Questions View all
Scroll button for the Logitech G502 Hero is not clicking
if the scroll button for the Logitech G502 Hero is not clicking so where’s the problem then and can i fix it ? (i mean the main click not the right and left scroll click) thanks in advance :)
Add a comment
Most Helpful Answer
The scroll wheel can be locked (clicky) and unlocked (freewheeling). Simply press the small square button just behind the wheel itself (marked with a pair of arrows in a circle) to switch between the two modes. Note that the button has needs to be pressed fairly firmly untill it clicks.
Score 3
3 Comments:
That's not what he meant
by
Fixed it for me!
by
fixed for me! Thanks!
by
Add a comment
Hi,
you might want to check out the disassembly and see if the scroll wheel assembly is clean and functioning. Proceed to step 9 for a “preview” how it looks on the inside:
Logitech G502 Hero Disassembly
In step 10 you can see the scroll click button between the two springs.
Score 2
2 Comments:
Hi! I just ran into the same problem OP was having with this device and upon further inspection, the area where the middle mouse button is pressed down seems to have a dent. The click in the mouse works about 1/4 of the time and there is no firm clicking like before. This damage occurred within the 30 minutes that I left school and made it home. The bag was not treated violently and the mouse has been used normally. Any assistance would be great. Thanks!
by
Wow Perfect Thank you
by
Add a comment
The click is likely permanently broken as the switch is just a little plate that probably got dented. It does not look easy to desolder but it might be possible. You can also just remap middle click to another button like one of the ones to the left of left click, personally prefer that over middle click now and the switch will last a lot longer
Score 1
1 Comment:
Yes. This was the problem. I had to purchase a new mouse.
by
Add a comment
When the same thing happened to me, I just went into GHUB and then changed the mapping of my buttons, removing middle mouse click from the scroll wheel and then setting the button behind the wheel toggle switch (the one that's normally mapped to be the onboard profile switcher, the I lock my key assignments so that it will remain the same for all of my games and applications
Add a comment
I had a similar issue with my mouse when it suddenly stop working. In my case it was not due to any hardware issue but moisture and dirt. Blow through strong air using any air pressure pump or vacuum cleaner if it have such feature for a few minute and it will most likely be solved. If not you might need to disassemble it and clean inside out.
Add a comment
clicked the button behind the mouse wheel all good
Thanks
for your comments worked well
Add a comment
Add your answer
Ahmed AbouRayya will be eternally grateful.
Past 24 Hours: 25
Past 7 Days: 121
Past 30 Days: 593
All Time: 19,088
