Hi @chillin014
Looking at the power board, the voltage to the LEDs should be 268V @ 380mA.
If the voltage and current is correct then this is all that you can go on.
If it is not this value, then you would need the power board schematic (I couldn’t find one online) to find out why or manually measure or test every component in the relevant section of the power board, out of circuit i.e. disconnect one leg from the board, to make sure that it is the value as marked.
Electronics engineers have designed the board and selected the correct component values to suit. This of course doesn’t mean that some components may have drifted in their set values over time thereby affecting the output.
Were the repair kits you found for your specific power board model (including Revision number)? If it was for your board then go with it. Repair kits were generally only issued when a problem became noticeable due to the high number of failures of the TV or the board.
If you’re not sure whether it is OK or not you could always try adjusting the backlight setting down from maximum (if it is there) so that they’re not operating at full current and check if the picture is still acceptable to you. Go to Menu > Picture > Picture Mode (Choose a picture mode e.g. Dynamic, Standard, Natural, Movie) > Backlight
