Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Front Facing camera not working.
After a display assembly, the front camera of my iPhone stopped working, I replaced the front camera twice and the problem still there. Could this be a logic board problem that means I need to replace the whole board? If so, what could cause this problem?
Score 21
3 Comments
To Johnkustic: I am having the same problem - Front camera not working after replacing the screen on iphone 4s. Is it possible for me to send the phone to you so you could do that little soldering job?
by
I got the screen of my iPhone 4 changed, since then the front camera is not working. Is it an expensive job to fix?
by
I was having the same problem. I remembered when I was having a problem with my texts not coming in, someone told me to whack it a couple of times, that worked. I decided to try it on this problem as nothing else worked, I whacked it a couple of times and wala it works. I can't believe it.
by
Add a comment
Most Helpful Answer
You probably damaged your logic board. There is a little chip above Audio jack flex connector. Check to see if it's still there. If it's missing, that is the reason your front camera stopped working.
You can create a little jumper to fix the problem. See this pic.
Hope that helps.
Score 8
12 Comments:
so if i use a bit of solder to connect both these points up it will work again?? should i use anything that will connect these two points?
by
Yes Patrick just join the two points with a little bit of solder and your camera will work again. I do it all the time for my customers.
by
John...please assist!! I have this exact problem. Front camera on my 4G not working, I check the board (which I bought yesterday) and sure enough, that little chip is missing. There is NO WAY I can solder this jumper - it's so small. Any suggestions?? Can you assist with repair?
by
Hi, Johnkustic, I am trying to help my friend to solve the same problem for the iPhone4. Before trying to solder the small jumper on the board, could you tell what's the jumper intended for? Is it bypass the control bus of the front camera? When the jumper is soldered, can the front camera come back alive? or the front camera is still not functioning but the phone will not screw up the camera application when flip the camera from back to front? Your kind help is highly appreciated. Thanks
by
Have checked the schematic of iPhone4, I found out that the small jumper is a ferrite beat F21, which introduce the 2.85V DC supply for front camera. It make sense to bridge it if the this component is missing, because no DC supply for the front camera, even the camera may powered from 1.8Vdc, but I don't know if it will be stable or not.
by
Show 7 more comments
Add a comment
There is a logic board issue whereby the camera, either front, or back camera is no longer recognized by the iphone 4. The only way to fix it, is to have the logic board component replaced. This service can be found on ebay.
Score 1
Add a comment
I researched this to no end and I think finally I resolved it. YOU MUST replace the front lens from the old screen or it won/t work. The lens pushes the camera to make contact with the steel shield on the back of camera which then grounds it to the under side of board. With out the it, it becomes useless because it isn't grounded correctly. I used a small metal ground between the camera and it's metal bracket for the ground.
Score 1
1 Comment:
By front lens do you mean that plastic piece that goes around the front facing camera?
by
Add a comment
When you replaced the camera, did you disconnect the battery 1st? If not...disconnect battery for a couple minutes & restart phone.
1 Comment:
Hi, Chuck:
Thanks for your answer. But yes I did that.
I have installed a new camera and the problem still there :S...
by
Add a comment
http://www.gsmindia.in/forum/apple-iphon...
Add a comment
My front facing camera was not workin on my jailbroken iphone 4. I disabled springtomize and then it was working so look in apps like ifile and springtomize to see if you disabled the front facing camera setting
Add a comment
1. Jailbreak your device
2. Download iFile
3. Go to System/library/CoreServices/SpringBoard.app/N90AP.plist
4. Set the value for front-facing-camera to false
5. Reboot
You will now not have the option to "accidentally" use the front facing camera.
Add a comment
Hi Patrick,
I see from your original post...you changed your display. So more than likely when you removed/installed the connectors at the top of board...you probably knocked a little chip off of it.
To test chip above audio jack connector, just solder across (bridge) both connections. If your camera works, just leave it that way. It will work fine.
Add a comment
Hi there I'm still having the same front camera problem like the shutter won't open and the camera/video icon flutters rapidly.. I have checked the little chip above the audio jack and its still intact .. the back camera works fine however .. help please
Add a comment
Made jumper as mentioned above- fixed a problem for me.
Add a comment
You probably damaged your mother board. There is a little chip above Audio jack flex connector check if it still there if it is missing that is the reason for front camera not working.
Hope that helps.
Hallo i tried this yesterday to make a jumper between this two points and after that my front camera worked perfect but it stopped to make calls the carrier was gone and when i was trying to make a call to somebody his phone was ringing but my phone it was dead i didnt hear anything. After that i removed the bridge to see if this was the problem but the problem was still there and the front camera stopped again to work. After few hours the problem with calls stopped without to do something. Do you have hear this before? It happend beacause the jumper or is something else that just happend?
Add a comment
You probably damaged another component of Logic Board by keeping the solder gun on a spot too long.
Add a comment
How do I make a jumper??
Add a comment
Txh...i fixed my problem after spend 2 hours!
BR Dejan
Add a comment
I'm having the same problem, but where is the Audio jack flex connector, I'm having a hard time locating where I need to solder, please help, pictures would be nice!
Add a comment
Thanks, it worked!! You are a genius! I've also a problem with a 4s mb (error 9, 21 itunes etc I've tried everything, it's a hardware problem). Where can i take a look on the Mb in your opinion? Gianfranco - Italy emai: docgian@libero.it
Add a comment
I want AE/AF Lock Solution.
Update (09/06/2015)
I Want AE/AF Lock Solution
Add a comment
How do I get the camera facing me?
1 Comment:
click on the camera like you are getting ready to take a picture and in the upper right corner there is an icon of your camera. Push the icon. That should do it. Do you see yourself:)
by
Add a comment
i cant make the jumper coz m miss the ground too..:( any other jumper please!!
Add a comment
i phone 4 farnt camera not waking
1 Comment:
plz.... halp me farind
by
Add a comment
Add your answer
gmbeto will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 94,964
