What is wrong with it, and what is needed to fix it
I accidently dropped my ipod on the polished cement while trying to throw a marker at my brother because he was throwing them at me but i dropped it on the cement face down no case, but has plastic protective covering by zag. i'm not positive but i think that when i dropped it it bounced and hit the ground 2 or 3 times when i picked it up the glass is horribly cracked (everyone i've talked to said that thats the worst one they've seen). now when i turn it on with the center button or the power button it turns on but the slide to unlock screen I cannot slide it to get into it or shut the power off (the touchscreen doesn't work), I seen that you guys had a front panel for the ipod touch but I dont know if it will fix the problem. what is wrong with my ipod? will this front panel fix it? if no is there a part that will fix it or a way that will. if yes will this be worth it and also i dont know if it is a 2nd or 3rd gen ipod how do you tell? and what is all the stuff i will need to fix this and will this be very hard thanks in advance you have helped much:)
1 Comment
I think you should talk with you parents or adult about this repair. I hope I don't upset you by assuming from your question and comments that you're in school? They may be able to help you do the repair or find someone who can do it for you. Oldturkey gives great advice :-)
by pollytintop
