Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
210 Questions View all
I lost the right speaker zip connector latch
Is there something I can do? I can’t find the info about the exact connector model…
Add a comment
1 Answer
Chosen Solution
Found it! BMU Cable Connector
You’ll want to carefully lift off the clamp bar off the new part and carefully slide it in. You may want to get a few just in case!
Score 2
3 Comments:
Thank you so much! So it's the same as the old mbp battery connector? even if it's for the speaker?
by
@vincy722 - You're thinking a connector is always defined by its function. So If I use a power extension cord for speaker wires does that mean I can't use it? No!
The physical aspects of what the connector is (or cable) doesn't always define its use. Here Apple used the same connector for the speaker (saving them having to source a different part needlessly)
by
Thank you for the clarification! I'm pretty new to all of this... ?
by
Add a comment
Add your answer
vincy722 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 93
