Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
replaced display,White screen, sound still works, buttons work,
I replaced my display screen for my iphone 4 and im only getting a white screen, everything is connected correctly, the phone still makes sounds, i used another screen that works on another phone and it still comes up white, any answers? I tried it on the iphone that works and it still comes out white so im replacing the screen but any other possibilities? I did lose a screw to hold down the board completely at the bottom left corner if it matters.
Score -1
Add a comment
Chosen Solution
I had dropped the phone and broken the screen. The screen i ordered must have been defective because i tried it on another iphone and it didn't work. I had restored the phone and did plenty of resets and it wasn't working. I finally took it apart and put the old screen back on and it works fines even though its broken. The problem was that i was missing a screw to hold the logic board down, with out that screw the lcd is rendered useless, as it says in the guide.
Add a comment
What was wrong with the original screen?
I believe the screen you bought is bad. Here is a quick check you can do:
With the GOOD screen installed on the phone you were replacing screen on...reset the phone by pressing the power & home buttons together until phone reboots. Hopefully you get the apple logo again.
My experience...when a white screen appears, the phone has to be reset...even when you install a good screen.
Add a comment
Add your answer
Daniel Corona will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 986
