The Samsung Galaxy A30S is a phone released by Samsung in August of 2019. It came with Android 9.0
My phone screen burned out and no longer works how do I fix it?
Score 18
11 Comments
Mera phone ma darara phad rhi ha
by
Dusra display dalna hai
by
السلام عليكم
جهازي اسقط في كاسة الشاي ولمدة يوم كامل لم اشغله
اليوم الذي يلسه تم فك الجهاز وقمت بتنضيقه ولكن يشتغل ويقفل من وحده .
هل في طريقه استطيع تشغيل جهازي اتمنى تفيدوني ؟
by
Camera border me pohne pleas help are you
by
my phone is working but the only thing that is problem is the screen is straight-up black
by
Show 6 more comments
Add a comment
Most Helpful Answer
u need to replace the screen
Score 4
2 Comments:
السلام عليكم
اليوم الذي يلسه تم فك الجهاز وقمت بتنضيقه ولكن يشتغل ويقفل من وحده.
by
عليكم السلام
سنسر التشغيل خاصتك متعطله يمكنك شراء غيرها و رجاع الجهاز كما كان و شكراً
by
Add a comment
mlokkaa83 the only thing you can do is to replace the screen. Something like this video should work for that repair
Score 2
Add a comment
Mon phone était tombé est dès lors le téléphone se manipule de sois même. Que dois je faire ?
1 Comment:
The digitizer has been damaged if you're experiencing the phenomena called "ghost touch" where the phone receives random touch inputs.
The display and the touch screen are bonded together, so the fix is to replace the screen. That will give you a new, working digitizer.
See @oldturkey03's answer for instructions on how to do that.
Le numériseur a été endommagé si vous rencontrez le phénomène appelé « toucher fantôme » où le téléphone reçoit des entrées tactiles aléatoires.
L'écran et l'écran tactile sont liés ensemble, la solution consiste donc à remplacer l'écran. Cela vous donnera un nouveau numériseur fonctionnel.
Voir la réponse de @oldturkey03 pour savoir comment procéder.
by
Add a comment
Add your answer
mlokkaa83 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,728
