Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1954 Questions View all
Can jailbreaking will fix error 29?
i replaced my old battery with a new one, it works for about a week,then when i upgraded to os5 in itunes, i ended up in error 29, my device is iphone 3gs 16gb
Comments:
think you need to downgrade not necessarily jailbreak, unless that is what you want to do? This is probably apple recognising an oem battery, so you'd need to try a restore to your previous ios..hopefully saved somewhere??
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
pollytintop, do you remember the fix suggested by Majesty a while back that would prevent iTunes from communicating with Apple servers? I wonder if that would help, if it has to do with apple recognizing the OEM (or not) battery. Why do I receive error code 29 when I attempt a restore? Also, I believe that OS5, even so apparently compatible with the 3GS, is still having to many issues. I'd wait for another update :-) So downgrading is probably the best solution.
Score 2
Comments:
just recently used that on an ios 5 update that went horribly wrong..on a 3gs! OT3 good call. It just makes itunes resend info instead of using archived stuff (I think). This is on the apple support website/advanced troubleshooting section which I can never seem to find..
by
Add a comment
Error 29 is most often a Hardware Error. It is an Error that you hope is due to your new battery being incompatible with your iPhone. If it is not due to incompatible battery, it is most often means a significant Hardware Error.
Score 1
Add a comment
I see a few error 29's and this is software and hardware
Restore it in DFU mode
To get to it, plug the phone into the computer and reset it by holding home and power together
Let go of power and keep holding the home button, it will say "iTunes has detected a iPhone in recovery mode" and click restore
If this does not work, it hates the new battery
Add a comment
Add your answer
chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 3,138
