Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
NO Charge, Home button function after Glass replacement
Just replaced the screen glass in the old 3G. Turned on ok but wouldn't connect/charge and home button wouldn't quit programs. Thought it might be the 1,2,3 connections, but no change. Now has dead battery. Any ideas?
Replaced Dock Connector again - to see if faulty. Still will not charge or turn on. Any ideas?
Add a comment
1 Answer
Chosen Solution
The lacking functions all have in common, Flex Cable #4, which is the Dock Flex Cable. Carefully reseat Connector #4 to the Logic Board.
So do I tighten the screw more? Does it need the sticker for insulation?
Score 2
Replaced dock connector (Thanks, Cable 4 was snapped through). Still won't charge or turn on.
Changed Dock Connector as advised. Now will not charge or turn on. There was a screw with a sticker covering it - is this important?
The Logic Board Screw with the "Do not remove" sticker can be important for battery function. This Screw helps to provide firm pressure over the battery contacts to the Logic Board contacts, allowing the battery to function.
The "Do No Remove" sticker is a warranty sticker. It has no importance in the iPhone function.
Add a comment
Add your answer
pdaviesoz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 377
