Repair guides and support for televisions manufactured by Sony.
706 Questions View all
Red light flashes 6 times and stops after switch on
My Sony KDL 32EX700 Red light flashes 6 times and stops after switch on. Please suggest the issue or any parts availability
Add a comment
Most Helpful Answer
Rajesh Ramachandran  here is what the 6 LED blink code means for your model.
It is a backlight error. You do want to go ahead and remove the back cover from your TV after you unplug it and take a look at the power board as well as the main board. Check for any obviously damaged parts. Post some good pictures of your boards and the interconnect cables with your QUESTION.Adding images to an existing question That way we can see what you see. After that, you want to go ahead and check the voltage measurement as pointed out on the flowchart.
That way you know which board you should replace. Let us know what you find.
Score 2
Add a comment
if you can’t google this
sony tv 6 flashes
to get things like this
Six red flashes means: backlight issue, bad main board, bad power board or bad inverter board. Try turning the TV off, unplugging and pressing the power button on the back of the TV while unplugged.
replacing parts is probably a bad and expensive idea.
Score 1
Add a comment
Add your answer
Rajesh Ramachandran will be eternally grateful.
Past 24 Hours: 162
Past 7 Days: 1,142
Past 30 Days: 4,908
All Time: 20,391
