Samsung tv UN55J6200AFXZA no stand by light
So I have a Samsung UN55J6200AFXZA that has no stand by light. I’ve done a little research from here but can’t find my specific problem. So I’ve replaced the power supply thinking that’s was the issue but no go. Both boards make the same clicking noise from the relay. I started unplugging cables and I believe i unplugged the one going to the screen, as it was the cable from the power supply that went onto the side with the screen not the main board, and got the standby light to blink 6 times and the relay stopped clicking. Plugged it back in and it started to click and light went out. Is my display bad?
3 Comments
I saw a YouTube video where the guy would disconnect the cord to the main board and his standby light would turn on. He replaced the board and it fixed his problems. Disconnecting the cable that goes to the main board does nothing for me. Disconnecting the cable that runs from the power board to behind the screen is what gets the standby light to flash then. When I do that I see the red light illuminate on the main board as well. That’s why I didn’t think the main board was the problem. What is the cable that connects to the top of the power board called?
by fsflyer56
fsflyer56 even so officially Samsung does not support blink codes, 6 is usually a backlight display issue. Disconnect the mainboard from the powerboard and see if you backlights come on. If so you know that the issue is most likely the main board.
by oldturkey03
Yea I believe it flashes that because I disconnected the cable to the backlight. If I reconnect it then that’s when the relay clicks and the standby light disappears. I’m guessing that means the backlight is bad. It doesn’t turn on if I reconnect that cable and disconnect the main board cable. Just gives me the relay clicks
by fsflyer56
