The Nintendo DS is Nintendo's seventh generation handheld game console.
41 Questions View all
Direction button is unresponsive?
Does the circuit board have to be replaced if the direction button is not working or can it be fixed?. It is only when it is pressed upwards all other directions seem to be working ok. The case has not been changed its the original.
Score 2
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
The rubber underneath the directional button needs replaced or the motherboard needs cleaned where the rubber piece makes contact. You will need a triwing screwdriver to take it apart. Be careful with the video cables. You will need to remove the motherboard to repair this. Instructions for that are here.
Score 2
Add a comment
Add your answer
fernanda will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 1,729
