Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
96 Questions View all
Trouble after restoring this iPod?
I just got this iPod off of ebay, I have had the same exact one before but never had any issues. Well it was having problems showing up in iTunes so I restored it. Problem is now all it is showing on the screen is the picture of the dock connector. I have tried plugging it into the wall, I keep trying to plug it into the computer, etc. It won't do anything. What can I do? Please help I am desperate!!
Comments:
UPDATE: I plugged it back into the mac I charge it on and it worked.. So maybe the battery is dead? I use the iBook to charge it and the Dell to put music on it. FYI.
by
Now I have gotten it to the point where it is copying my library to it, then it all the sudden just dies. I think it might be the battery? I charged it for about an hour and it was showing little charge? Are these easy to switch out batteries or should I return it to the person that sold it to me?
by
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
iPod 3rd and 4th generation will require a Firewire Adapter to sync and restore, they do not use USB. USB Support: Sync Only Firewire Support: Sync & Charge
Details: The iPod 3G models are capable of charging and syncing by Firewire via the dock connector. These models can only sync using USB.
Connectivity: Firewire & USB Ports: Dock, Headphone*
from here You will also need a Firewire AC adapter to restore the iPod. You may not need a battery, it might only be flat due to not receiving a charge through the USB.Hope this helps, good luck
Score 1
Add a comment
Add your answer
Sarah will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 356
