Repair guides for the MacBook Air, Apple's current line of consumer laptops.
2483 Questions View all
Volume bar is at max but the volume is very low?
Volume bar is at max but the volume is very low. Please help to get the increased volume.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Have you made sure that all your sound levels are turned up? You need to make sure that the computer sound (adjustable via the keys on your Air) is turned up AND the volume of the application playing sound is also turned up. If those are both turned up try changing between speakers and different headphones to isolate if it's a speaker problem. If sound level varies greatly between head phones, a pair of headphones is likely broken. If headphones work fine but your Air speakers are still exceptionally quiet, you may have a loose connection or damaged speaker. You can use our MacBook Air guides to help get into your laptop to investigate.
Let us know what you find!
Add a comment
Add your answer
Rajinder Singh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 166
