The iMac Pro, is Apple’s most powerful iMac to date. It comes with either a 3.2 GHz 8 core, 3.0 GHz 10 core, 2.5 GHz 14 core or 2.3 GHz 18 core Xeon W processor. EMC 3144 / A1862 (ID iMacPro1,1)
Can I replace an 8 Core Xeon processor with a 18 Core Xeon Processor?
Can you replace the 8 core processor in a iMac Pro with an 18 core processor in a
iMac Pro?
Score 2
Add a comment
Most Helpful Answer
Yes! There is no problem as long as you use the correct CPU! 18-Core Xeon W-2191B
Now before you do this consider the clocking Vs threads issue!
  • 3.2 GHz 8-Core Xeon W-2140B
  • 3.0 GHz 10-Core Xeon W-2150B
  • 2.5 GHz 14-Core Xeon W-2170B
  • 2.3 GHz 18-Core Xeon W-2191B
A single threaded process will run faster on your current system and much slower on the 18 core! As the clocking has a large effect here.
But!! A multi-threaded application can leverage the multiple cores of the CPU, but you do need meter how many cores makes sense given your work load.
I often find people go crazy going with too large a chip when a middle version would make more sense!
So if your multi-threaded work load is using more than 2/3rds of your work day then consider the bigger chip, I would still see if the 14 core will be enough. If it’s less than 1/2 of your work day maybe the 10 core is enough.
Just like Goldilocks and the three Bears! There is a balance! Not going too small or too big!
Here’s a guide to get the display off iMac Intel 27" Retina 5K Display 2019 Display Replacement we don’t have an guide’s explicitly for the iMac Pro. Review the iMac Pro Teardown to an idea what’s involved.
iMac Pro Image
Guide
iMac Pro Teardown
Difficulty:
Moderate
iMac Intel 27" Retina 5K Display 2019 Display Image
Guide
Difficulty:
Moderate
15 - 40 minutes
Score 5
Add a comment
Yes, you can replace but you should not doing it because your computer components will not bear the 18 core Xeon processor but if you have the TDP then it is possible
1 Comment:
FY - Apple sells the system with the 18 core chip so there is nothing wrong with the configs TDP.
by
Add a comment
Add your answer
Doug Moore will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 65
All Time: 1,970
