2.26 or 2.4 GHz / White plastic unibody enclosure
631 Questions View all
Is my logic board safe?
I recently purchased a macbook off eBay, it was considerably cheap, because in the description it said the keyboard was very buggy and would type different letters other than the ones pressed. I am wondering if its most likely the logic board or the keyboard itself? keeping in mind that the track pad works perfectly and when an external keyboard is used it works perfectly.
Score 1
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Your logic board should be fine. The keyboard in the upper case emulates a usb keyboard and goes through one of the usb channels. If the keys on it are functioning at all correct or incorrect key the logic board part is good. Use your external keyboard to reset your PRAM and erase the library files for the keyboard. If that does not solve your problem replace the upper case with the keyboard.
Score 2
Add a comment
Add your answer
Taylor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 455
