Repair and disassembly information for Samsung's flagship S20 Ultra Android smartphone, released in March of 2020.
14 Questions View all
Why can't I install YoWhatsApp APK 2021 on my Samsung phone?
Recently, I was introduced to using YoWhatsApp APK by a friend, this version has a lot of useful features, especially it has an interface store with hundreds of beautiful themes for users to freely change according to their preferences. So I also want to install it for my samsung s20 but I don't know how to install it. Has anyone used samsung installed it and can help me?
Thanks
Add a comment
You can simply use the Play Store app.
Note: You won’t see incompatible apps when searching via Google Play on your Android smartphone or tablet. They just won’t appear in the search results.
Android is an open-source platform and, thus, you have more options than you do with something like iOS. One of those freedoms is the ability to install third-party apps from outside of the Google Play Store. It’s not a practice we recommend because the Play Store has so many security measures. However, for whatever reason, you want to install something from somewhere else. You can definitely still do that.
There are two ways to install third-party apps without the Google Play Store. The first is through third-party app stores like F-Droid, Amazon’s App Store, and others. The second method is finding APKs from websites and manually installing them.
Note: Android devices include a build.prop file that identifies the model of the device. if you have a rooted Android device, you can edit the build.prop file and make your device appear to be another device entirely. This will allow you to install apps that are marked as compatible with the other device.
Add a comment
Which S20 Android version you are using? if you are using android version 11 then it is possible that you can’t install YOWhatsApp Apk on S20 because this app is recently updated, check for it’s updated version on net and then try it otherwise if you are using android 10 and you have this issue then I think you have to install this GBWhatsApp and I hope it will solve your issue.
Add a comment
Add your answer
SaraCohen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 7
All Time: 33
