Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1959 Questions View all
Why can't I make calls.
Done a phone delete, downloaded to i tunes, everthing esle works just can't make any call.
Add a comment
Chosen Solution
Does the phone recognize the sim card? Are you using AT&T or another carrier? If the phone was previously unlocked you might have just removed the unlock so now it wouldn't work for tmobile (non AT&T carrier).
If you are using AT&T, what was the phone doing prior to you restoring it? Was it having trouble with something specific?
If the phone does not detect a sim card you may have broken the sim reader when taking the sim card out. That would require fine solder skill and a cheap part.
Hope this helps a little
Score 2
Add a comment
Most Helpful Answer
have you reset network settings in "general"? This may be the cause of the problem...otherwise if you have a previous backup of your iphone then try that.
Score 2
Add a comment
Add your answer
jason will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 748
