Guides and repair information for assorted graphics cards, also known as video cards, graphics adapters, or display adapters.
110 Questions View all
MSI RX 570 GAMING X 4 GB - What are these missing components?
I need help to find out what are these missing components. All these are the same ?
I get that card like this and if I can fix it I will use it.
Thanks from now.
Add a comment
1 Answer
Most Helpful Answer
are you sure that is whats wrong with the card? many manufactures leave spots blank dependant on what kinda card it is. so unless you know for a fact that stuff goes there you could end up bricking your card. your best bet would be to try and find disassembly pictures of your card and go from there.
Score 1
4 Comments:
side note: if its labeled "C" with a bunch of numbers odds are its a capacitor and R usually means Resistor. hope this helps a little
by
@logixal Yes I am sure these spots are filled with components in normal as you can see here (https://www.techpowerup.com/review/sapph...) And I wasn't know the C-R labels thank you so much for that. At that point we know these are capacitors but we dont know their specifications.
by
@mkose yea unfortunately 98% of the time its VERY hard to find actual schematics for cards as they dont want to you to be able to repair them.
by
@logixal actually I think I found the schematic but I only understand that they are 100nf capacitor but how many Volts ? (https://pdfcoffee.com/rx580-rx570-rx480-...)
by
Add a comment
Add your answer
MkosE will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 160
