The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
282 Questions View all
My battery folded during lcd repair.. is this?
My battery was pretty stuck and got folded and dented during the process of removing it. I have bent it back in shape but will it still work?
I also damaged my home button flex because of the battery I thought nothing was beneath it. So I want to know if I need to order both or if it is normal for a Li on battery to be "moldable"
Comments:
I repair, refurbish & restore iPhones & iPads & iPods. I taught myself. So the learning curve was not forgiving. I have now done over a dozen iPhones and 7 iPads. I have the iPhone 6 too, 1st gen/model. It's approaching 2 years come August & im ready to upgrade, exchange whatever. But my battery had become dreadful "in my terms" compared to what I expect from my Apple products, and typical battery discharge & charge rates after X # of cycles. I order a high capacity 2680 Gold li-ion battery for my model iPhone. I was honestly excited! It arrives & I cockily just go to operate on my personal iPhone, & realize the battery is insanely, over-board, glued on!! Like...WHAT!
Now I look up videos & it's the norm but technique varied. That was the competition. So, I finally get under my battery, start removing it & I had no choice but get my device really hot! Unsafe hot! But it [battery] bent, bowed, & I intentionally kept molding, forming it back to its flat shape just as it happened and I decided I would look for info or videos on "status of" bent, bowed or slightly mangled iPhone 6 batteries. Thrush: this 'high capacity' battery sucks! It discharges rapidly! I wanna go back to my OEM battery but have never, not once, placed/replaced a battery not new. So I don't think I can. I believe it will malfunction & destroy my device & possibly hurt me?! Is that your findings sir?
Did you put your old mangled battery back in your iPhone 6
by
Check out the top comment, using this battery is not safe and it is better if you buy a replacement
by
Add a comment
Chosen Solution
Lithium batteries should not be bent, folded, spindled, mutilated, manipulated, shape shifted, or used in any process that involves changing the case's shape. The insides of these batteries are lined with metal plates (I forget what material specifically) that can separate, break and otherwise be damaged. Plates that aren't supposed to touch can also come in contact in cases of extreme deformation.
Will the battery still work? It may or may not, only way to know is to measure voltage or try it. Just be careful! There is a fire hazard with severely damaged lithium batteries, just youtube "lithium battery explosion"...but of course those are extreme cases and go long past the point of noticing "hrmmm, something wrong here".
The flex cable replacement depends on the severity of damage. Did you cut through any of the traces? Is this cable also severely "molded" to the point where it may have broken the traces?
My PERSONAL suggestion would be to just grab both if you can. It will save you time and frustration later! Good luck.
Score 3
Comments:
I will be replacing both also that ribbon is replaceable but ill do that at my univercity with beter equipment. I dont know why but that battery was pretty hard to get out...
by
One word...GLUE! :]
by
Add a comment
If you cut through the ribbon beneath the battery the game is over. That's part of the logic board.
If that is the case I suggest taking the rest apart for practice so the next time you know its secrets :-)
Add a comment
Add your answer
rens will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 61
Past 30 Days: 254
All Time: 7,762
