Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3237 Questions View all
I ruined the antenna connection on the mother board, any suggestions?
While trying to reassemble my iPhone (reconnecting the antenna wire) I damaged the area that holds the antenna wire and now I can't get it to stay on. It's the main antenna so I no longer get phone service. Wifi works fine but no phone. What do I do now? Can I solder it? Any suggestions?
Comments:
hello i also have this problem sis you fix yours ??
by
I wasn't able to fix it. I don't think I have the skill level to solder it myself this is not an option for me. My iPhone now sits in a drawer.
by
Add a comment
Chosen Solution
Indeed the best (and only option in my opinion) is to buy a replacement connector and solder it on. If you have some soldering skills it is not too hard a job.
I'm having difficulties to find one on EBAY. If you are realy desperate to find one please let me know and I might be able to get one for you.
Add a comment
Did the connector on the board get damaged or did the part that plugs in get damaged? If the part on the board is damaged and it's not getting a signal, then you would want to find the part and solder it back (being careful not to nick the other components?
Thanks
Add a comment
Add your answer
Jose Codallos will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 2,634
