Xbox series X not turning back on after crashing
So I downloaded Elite Dangerous on my Xbox but it kept crashing, so I tried one more time, then it crashed fatally,and turned off my xbox completely, it did switch on after that with a cold boot, but as soon as it loaded up the homescreen, it shut off again, since then it hasn't turned back on, when I press the power button the logo does glow up and emit the startup sound but it shuts back off after a couple of secs, so I peeked from up top and then saw that when I press the power button the fan doesn't start up with it, which it should and then my xbox turns back off as the fan doesn't start up, but sometimes when I press the power button i do see the fan move a bit, like it tries to spin but then stops soon after and shuts off the console, the disc drive still accepts and ejects discs but hard reset, usb update, troubleshooting mode, none of these methods work, it has been originally imported from Singapore to India so here in India the power outlets have 220v instead of 120v in Singapore, could this be a power supply issue? i use it with a pin adaptor which is rated as 6A, 240V
